Commonly Asked Questions
See also: the Raspberry Shake Forum where you can easily search the archives for questions similar to your own.
Installation
Anchoring: How do I anchor my Raspberry Shake to the floor?
Question: The Shake box seems to come with some nice trim screws to set it level. How though is the unit meant to be coupled to the ground/concrete/slab/table…? The last few earthquakes I’ve experienced here in New Zealand would of sent the Raspberry Shake bouncing off the table or sliding over floor which means it will not actually be recording what it is meant to? How is it proposed to couple it to the horizontal surface?
Answer: Shake does not need to be “anchored”.
Raspberry Shake is a weak motion device, like most seismometers are. It is designed to measure sub-micron movements. It probably completely clips between 0.1 and 0.2 g.
If during an earthquake objects are in the air then surely 1 g has been exceeded. Just yesterday I was watching youTube videos of the last New Zealand earthquake and yes things were moving. Shake and any other seismometer would be totally saturated and the data would be useless even if they were anchored.
Seismologists use accelerometers which have a range above 1 g commonly set to 2 g and can be set to 4 g. These devices are anchored. In a Class A seismic installation you would have a seismometer, and accelerometer that goes to DC and a GPS. This would allow for the huge dynamic range that you will get in a large earthquake. The accelerometer to DC and the GPS would allow you to see the displacements that a velocity sensor like the Shake will not show.
How precisely does Raspberry Shake need to be leveled?
Answer: This is a good question and one that is tossed around here at Raspberry Shake. Geophones are made by lots of companies and in lots of natural frequencies and cases and coil types. We think that the geophone used in Raspberry shake will have over 95% of it output out to about three degrees. A quick and dirty test of the undamped output of the Raspberry Shake’s 4.5 Hz geophone was performed. We did the test at 10 Hz to get away from the amplification of the resonant frequency. We moved the geophone 1 mm. 1mm at 10Hz is strong shaking. From 0 to 3 degrees of tilt we could not see any significant difference in the output. It was not until 6 degrees that we could see a change and not until 15 degrees that the output was meaningless.
We can definitely say that if the leveling bubble is mostly within the little circle on the level built into the acrylic box, that things are ok. From the test we have done, I think that the leveling bubble we provide will achieve the +/- .5 Degrees as long as the leveling bubble is centered in the circle.
Later, one of our backers, Brett, responded: “I did a quick test to check the leveling bubble sensitivity. It took about one turn of the leg screw located on the center line to move the leveling bubble from centered to be solidly touching the black ring. That’s 0.8mm over 123.5mm, the perpendicular distance from that screw to a line between the other two legs. That ratio is 0.00648 and taking the ArcSin = 0.37 deg. of tilt, which is slightly better than you suggest. Probably the biggest factor will be how well the geophone guts are aligned with the leveling bubble. Super leveling is not going to be an issue.
Why does my Raspberry Shake change IP?
IP addresses can either be “DHCP”, that is “D”ynamically assigned, or “Static”. Most routers today dynamically assign IP addresses. That means that every time a computer like the Raspberry Pi is connected it is given an IP address. It can be the same IP address as previously assigned or a new one. The connection is time limited. Some routers set it to a day or so, some months and still others many years. So, depending on the router settings, the connection will be released and reconnected after a certain time window. On some routers it is possible to change length of the time, on others not. For example at a university where many people come and go, the time window is set to shorter time so that the IP address can be recycled. At home where you have fewer computers, you would obviously prefer a longer time window. The solution around this problem is to set a Static IP address. See here for instructions: Static IP
Hardware
Is the schematic for the Raspberry Shake available?
The schematic for Shake is not available. Much of the software is open. Our reason for not making the schematic available is that if we made the hardware open and the firmware that went with it, we would see Raspberry Shake on Alibaba before the Kickstarter campaign was even over.
We align ourselves in many ways with the folks at Pololu when they make this statement about open hardware: See article here. Pololu put a huge amount of work in writing that piece, long but worth the read.
What is the difference between the RS1D, RS3D and RS4D models?
_images/Comparisons.png
Click to enlarge
*sps = samples per second on all channels
The RS1D, RS3D, RS4D and RS&BOOM have the same capabilities for detecting Earth motion in the vertical dimension. The RS3D replicates these abilities in the horizontal dimensions, providing the user with a fuller view of Earth motion in all 3 dimensions. The difference between the RS1D and the RS4D is that the RS4D has a 3 dimensional accelerometer built into the board. This is interesting for people who live in earthquake zones where the strong motion might be enough to saturate the vertical sensor. With the accelerometer, the Earth motion would remain on scale with the added benefit of being able to detect lateral motion as well.
Why can’t I mount/ stack multiple Rasberry Shake boards on the same Raspberry Pi computer?
This is because the RPi computer only has one serial port (Rx/ Tx) connection. See GPIO pins.
Software
What is the username and password?
Username: myshake
Default ssh password: shakeme
See also: How to change your ssh password.
Do I need a software license to use my Raspberry Shake?
See our: License
Additional note: All Raspberry Shakes purchased during the Kickstarter campaign are exempt from the license requirement.
Should/ Can I update the Operating System?
We do not recommend updating the Raspberry Pi’s OS The problem with updating the OS, without regard to the operating environment it supports, is that the possibility exists for the update to break some instance of infrastructure on which the executing system relies. It is possible that the Raspberry Shake unit will simply stop functioning and you won’t know why. Rather, it is preferred that the maintainer of the system fully understand the implications of any OS update on the system itself before allowing such an update to take place. Only once an OS update has been fully vetted (vs. all activities it is required to support) should it then be rolled out to individual units in the field. For more details see: Ready, Set, Get Hacked! Security and Raspberry Shake.
How do I report bugs?
Please send an email to the Feedback section of the Community Forum list with the subject: “Bug Report (<Tool>): <some summary message here>”
Is there a unique SD card image for each model of the Raspberry Shake?
All models of Raspberry Shake, including the RS1D, RS3D, RS4D, RBOOM, RS&BOOM and RJAM use the same software.
